Blown head gaskit i think ?
Pete, check this thread out, it features a bit of good advice from Wil on how to check your head gasket for leakage
http://www.moparuk.com/forums/viewtopic ... ght=#97047
Re: Blown head gaskit i think ?
Am I reading this right?? hose swells AFTER the motor is turned off ??pete walton wrote:symptoms are top hose swells when engine turned of something must be loading up the pressure ?
If head gasket i'd have thought it can only build pressure while the engine is running.
Hoses would be rock hard well before it was switched off, spitting water etc
could be a localised hotspot in the block that boils water once the water pump stops circulating ????? just a guess
A rad cap can't usually fail that way, if you take it off the rad and push the lower portion and it moves the cap is fine, basically a spring keeps the lower seal on it's seat, as long as the lower bit moves it's ok
are you sure it's not just the hose in question is weak, all hoses have to stand between 12psi and 20psi ish depending on the cap rating
