69 Charger Grille removal
Hi guys any advice on this, please ? Not done this partular job before, thanks.
Remove front scuttle panel.
Remove the bumper complete with irons , two bolts each side into the frame rails.
Take out front grille complete with slam panel , which is bolted to front wings top & bottom , also disconnect wiring harness from light assembly.
Be real carefull when you separate grille from slam panel , if you can remove the bolts without braking summit you should of gone into brain surgery.
RayC
Post by RayC »
Dont think the crowbar will help ray.
The charger grills are usually able to break without much brute force. :shock:
All out, not broken - as per Adam's excellent instructions.
Just need the repair parts now......Grille spacers, bolts, etc. And lots of glue.......
pete,
i'm ordering the spacers from year one in the next week or so, i was thinking of getting stainless coach bolts. you want me to double the quantities? black or white spacers?
Pete wrote:All out, not broken
:shock: :shock: That must be the quickest grille removal in history. :D
Love the crowbar. :lol:
Good to meet you last week Mark. :thumbright:
It was awesome to meet a few more members, blown away with alan and your engines. Tis truely a stunning sight. Seeing your motors gave me a a kick up the arse to get on with mine, hoping to get her to the nats for sure. Got all of april off so hoping to have her running by the end of then.
marknlindsey wrote:pete,
Hi there! Black spacers and bolts would be great, thanks. Biggest problem is that I need a replacement "I" section, and they are SOOOOO expensive. :cry:
ok pete i'll mail you when i order
If you get stuck, I have a spare set of grille spacers in black.
Thanks Clivey, that may be handy as I want to make the Wheels day :thumbright:
Well P.M. me your address if you want them Pete and I'll get them in the post toot sweet.
I have a white set too, but they are for my car to replace the white originals. :thumbright:
What a star :thumbright:
