I take it the timing is locked out? , if so & you are using the start retard facility (25*) along with a crank trigger , just be sure to phase the rotor , problems can arise when the start retard pulls too much spark lead on start up & misfires to another terminal in the cap , can also happen when using a distributor without a crank trigger , CHECK THE ROTOR PHASING.
Whichever way you run the motor (boosted/nitrous/NA) , if using a crank trigger phase the rotor for highest rpm/cylinder pressures.............if the motor runs say 30* advance @ max RPM , then phase rotor for this timing figure , if using spray then phase for the maximum retard being pulled.
Look forward to seein the car Pete , glad it's coming along.
