This is a list of OEM parts that were still available from Chrysler. Usually these can work out cheaper from a Mopar dealership than places like Year One etc.
This list is several years old so prices may not be accurate and some of these parts may be now discontinued, but they may be in inventories at different places around the US that dealers can search for.
part num, description, price
4797146 A/C dryer $67.75
5010125AA ATF DEXTRON 3 1 GAL $12.50
4383441 backing plate-brake-support-left 11x2.5 drums $77.50
4383440 backing plate-brake-support-right 11x2.5 drums $77.50
4173447 balancer- A engine engine cast crank $180.00
2951673 balancer- A engine steel crank $340.00
2265938 bearing-clutch torque shaft, 4 required all models $2.25
2405077 bearing-throwout assy 10-1/2" clutch $77.10
2265656 bearing-upper, steering column 66-71 all models $20.10
6033795 bolt- square head battery terminal a/m $1.70
6023092 bolt-attaching A engine windage tray 4 req $2.25
6035462 bolt-flexplate to crankshaft, all models $1.70
6030536 bolt-flywheel all engines $13.75
6036207AA bolt-harmonic balancer-A & hemi engine $5.50
6029799 bolt-self locking shifter plate $2.85
6029713 bolt-timing cover A engine $2.95
3491296 bolt-U, rear end 6-5/8" long $11.30
0220800 bolt-viscous fan bolts 4 req $2.25
6026919 bolt-w/washer trans housing dust cover all models $7.00
6027865 bolt-w/washer transmission to engine, 4 req all engines $2.70
6024863 bolt-w/washer-engine to trans/bellhousing 2 req all engines $4.50
3515300 boot-clutch fork bellhousing $14.45
2269214 boot-lower balljoint All V,L,B,J,R,W,X Models $8.20
2996454 boot-shifter 4-speed 68-70 B body w/console $67.10
2950074 boot-shifter 4-speed 68-70 B body without console $72.00
3467766 boot-shifter 70-74 E Body, 71-74 B body Square hole $65.95
3467764 boot-shifter A body 4-speed $68.25
2835896 boot-tie rod end $6.35
3402575 boot-torsion bar '73-up B, X, S. E T R-body $12.75
2071173 boot-torsion bar rubber boot all models exc imperial & c body $17.20
2269127 boot-upper ball joint all models exc A & Y body $9.50
2951834 bracket-A engine alternator mounting-non A/C $7.00
2951747 bracket-A engine pwr steering 1970-79 $17.00
3880999 brake-rear T and hose assy 70-74 ABE body $48.95
53030254 breather-valve cover single outlet round gold colored $10.01
5216050 bumper-glovebox door hinge-E body $1.70
2535027 bumper-lower control arm rebound A Body $18.45
2784714 bumper-rubber hood leveling-rear corner-all models $4.10
2276804 bumper-rubber leveling-fender extension to hood $2.20
4014050 bumper-upper control arm all models $6.95
2801724 bushing-A833 4-sp & 727 AT tailshaft $9.10
3575333 bushing-AT linkage-rubber 1974 & up. All models $2.50
3575434 bushing-AT trans linkage-used from 1961-96 on all models $2.00
2269709 bushing-C body sway bar $12.00
1940725 bushing-rear shackle-all A Bodies $4.95
1400269 bushing-rear spring shackle-all models exc A body $3.75
2071204 bushing-upper control arm 67-72 B body, 70-74 E body $16.75
2884730 cable-heater temp control 70-74 B,J,R,W $25.00
2983778 cable-negative battery 70-72 B/E body all engine, 70-72 A body $14.10
4450615 cable-negative battery V8 , H N $30.20
4294951 cable-parking brake equalizer, all 1970-71, exc 71 B/E body $4.60
2770662 cable-positive battery 68-73 A body A engine $123.00
3764166 cable-positive battery 72 B body A engine $28.75
2983649 cable-positive batteryc 70-1 E body 71-72 B body B-RB engine $28.35
4897646AA cable-speedometer, A, B, E body 1966-74 $38.45
3769123 cable-throttle A engine 360 4bbl, fits 74 up w/ 360 $44.50
2899339 cable-throttle-68-71 383-440 engine, B body $49.00
3418839 cable-throttle-overall length is 23". 70-74 E Body, 71-80 B Body $38.45
2889785 cable-trans to cruise control servo 1967-1981 models
2880829 cam-canceling-turn signal switch $121.00
4315764 camshaft-thrust plate A engine $6.50
3580894 cap-front wheel bearing cover 72 & up all models $7.25
1613416 cap-front wheel bearing, all models exc 9' brakes up to 1972 $7.25
52079880AA cap-radiator all models 64-91 $9.50
2497500 cap-windshield washer reservoir a/m $2.45
2951544 choke well cup B-RB engine $28.95
2951545 choke well cup gasket, B-RB engine $3.25
4343950 clamp-A engine distributor $4.20
4041606 clamp-A engine silicon bypass hose $4.50
2892399 clamp-speedo drive pinion adaptor housing all models 64-89 $3.70
3454220 clip-door handle to latch rod-70/71 V,L,B,J,R,W,X,P,D,C $2.50
3454221 clip-door handle to latch rod-70/71 V,L,B,J,R,W,X,P,D,C $2.50
2405049 clip-fender seal or cover on inner fender $0.95
6023285 clip-retaining for 3418899 & 2418900 throttle cable stud $0.95
2201467 clip-retaining, emergency brake rear cables a/m $2.10
1838508 clip-spring, distributor cap hold down all Chrysler distributors $1.75
2217508 clip-window belt w/s outer/inner all V,L, outer only all BJRWX $0.25
2892263 clutch-pivot fork B-RB-Hemi engine B,J,R,W models $26.05
2461765 clutch-torque shaft pivot engine side $21.25
2461766 clutch-torque shaft pivot frame side $46.70
2495531 coil-ignition all engines/models $42.10
5211126 connector-windshield washer hose All E & 71+ B Body $2.95
2204728 converter-door drain, 727 all models $1.45
3575303 coupler-steering column 73+ R,W 65-73 full size Chry/ply/dodge $84.10
4443436AC coupler-steering pot rebuild package $9.25
6028750 coupler-steering roll pin $1.75
3748263 coupler-steering shaft $9.95
3748310 coupler-steering shaft C body w/tilt-tel $9.95
2843892 cover-bellhousing inspection A engine 4-speed $45.25
3751249 cover-goes in place of air tube on exhaust manifold,1975& up A/B/RB engines $10.45
3769964 cover-timing A engine 69-79 $154.00
2899530 crankshaft-oil slinger, all engines $6.75
2964116 decal-roadrunner deck lid 70-71 standing bird $20.75
4022410 decal-roadrunner running bird rt side 68-78 Roadrunner $17.20
3749059 decal-roadrunner-Standing bird w/helmet 73-74 Roadrunner $13.70
4874000 differential-sure grip additive $5.25
4202951 dip stick-oil level indicator 904 & 727 trans exc Hemi $9.45
2466302 dipstick-auto Trans oil level all models 904/727 $9.45
3698500 dipstick-B-RB HP engine 1970-71 $10.20
2899246 dipstick-B-RB motor 1968-9 $10.00
3656738 distributor-pick up & plate V8, 72 & up electronic ignition $24.45
3656862 distributor-reluctor, all V8 electronic ignition $7.50
1122532 dowel pin-engine to trans locating pin 2 req 0.500 diam $1.85
Original parts still available new from Mopar
- Dave-R
4037651 extension-shaft converts manual steering box from pwr strg $268.00
3462185 fan-4 blade engine cooling, 6 cyl & hemi $55.25
6008109 fastener-insulation to firewall plastic $3.85
2084467 filter-5/16” fuel, fits all Mopars $7.60
1670694 filter-gas tank sending unit pickup,5/16” a/m $6.25
3515996 filter-trans all 904/727 AT $7.60
4058429 flexplate-10.75" converter, 727 Automatic $40.70
2204768 flexplate-11.75" converter, 727 Automatic $86.95
4051004 float-gas tank ass'y all A bodies $84.20
3410038 fork-4 speed steel shifter, 1-2 gear $55.85
4130068 fork-4 speed steel shifter, 3-4 gear $70.20
2880434 gas tank-68-70 Charger only $340.00
3420848 gas tank-float ass'y 68-70 B body exc hemi $138.00
3420849 gas tank-float ass'y 68-70 P D C model exc station wagon $119.00
3420844 gas tank-float ass'y 70-74 E body exc hemi $108.00
2124499 gasket-4-sp main drive pinion retainer $2.60
4186180 gasket-6 cylinder intake/exhaust $2.25
2070933 gasket-8-3/4 axle foam-backing plate to axle $2.35
4295875AC gasket-904 pan-reusable plastic $11.95
4106552 gasket-A833 4 speed transmission kit $28.35
2889935 gasket-antenna base all models $2.60
3514186 gasket-aux port intake for B/RB 6 pak & aluminum intakes $27.35
1302807 gasket-backup light switch manual trans-all models $1.20
2801893 gasket-bearing retainer A833 4-sp $1.70
3739844 gasket-door handle, A/B body $2.50
2287938 gasket-EGR A engine $3.00
2843770 gasket-fuel pump, all models $2.10
2932280 gasket-neutral safety/backup light switch $2.20
55074799 gasket-outside keylock all models exc B,J $1.95
2801398 gasket-tail shaft bearing inspection cover $1.60
2466954 gasket-tail shaft to main housing torqueflite trans $2.25
4095088 gasket-valve cover A engine high perf $19.10
4027092 gasket-valve cover B/RB engine high perf $15.70
53021051AB gasket-water outlet intake manifold A engine 1979 & up $2.10
4354047 glass-rubber insert 68-69 B Body. Slides into rear channel $39.35
3672933 grille-lower 72-74 'Cuda & Barracuda $78.75
2946079 grommet, valve cover breather $3.95
4271382 grommet-check valve pkge, Bendix pwr brake booster $16.35
3404182 grommet-gas tank filler tube 66-70-74 B & E Body & 67-74 A body $15.45
3751510 grommet-PCV valve cover $3.95
4694335 grommet-pcv valve/valve cover $5.95
3593446 grommet-speedo cable thru firewall-all models $2.75
J3201032 guide plate-brake shoe, 11" brakes $3.10
3882621 handle-door HNFGXSET $61.60
3760215 handle-door lt side 1970-74 E body outside $98.45
3760214 handle-door rt side 1970-74 E body outside $98.45
3454391 handle-door, left outside 68-70 A & B-Body $77.70
3454390 handle-door, right outside 68-70 A & B-Body $77.70
4436772 hardware-brake pkge 10” brakes $23.25
4436773 hardware-brake pkge 11” brakes $23.25
3683947 heat riser-package 340 engine $38.10
82300749 heater-engine block package, use 2 for a V8 $33.00
55076269 hinge-67-70 B-Body lower door right & left $50.70
2486468 hinge-door bushings $2.60
3454510 hinge-upper door 71+ B body $89.85
3788534 hinge-upper door 71+ B body lt side $89.85
3443894 hood-fender rubber bumper, all A bodies $2.50
4741932AB hose-5/8 heater 50 foot roll $57.50
4241310 hose-pre heater carb air all 6 and 8 cyl engines $16.00
4883434AA housing-repair package speedometer pinion all 64-76 models $7.85
4111850 ignition-control box-electronic $53.50
2806779 insulator-67-76 A engine A body $32.10
2536121 insulator-engine; 70-72 E body, 66-72 B body w/ A/B/RB engine $34.70
2956754 knob-door lock, chrome $2.50
4216907 latch-glove box lock cyl 70-75 VL, 70-74 BJPD $34.20
2822583 lens-glove box light, round, 66-76 most models $4.85
2292995 lens-round dome light all models $16.25
3587436 lens-side mkr, front-amber 72-80 B body, A body, F body $11.70
3587440 lens-side mkr, rear-red 72-80 B body, A body, F body $10.25
2947963 lever-turn signal A & B Body $47.20
2947953 lever-turn signal E-Body $50.00
6031535 lug nut-chrome-use for super coupes and kit car wheels $4.35
2823849 lug nut-lt hand thread chrome wheel lugs 4-1/2 bolt pattern $4.25
2823848 lug nut-rt hand thread chrome wheel lugs 4-1/2 bolt pattern $4.25
2409826 lug nut-rt hand thread, steel wheels $2.45
3681601 magnet-auto trans pan, all models/years $4.20
3695508 mirror-remote lt side 66-70 B body & 68-76 A Body $394.00
4480313 motor-pwr window left side all models 66 up $169.00
4480312 motor-pwr window right side all models 66 up $165.00
3642818 mount-engine spool type A engine right side $40.65
4032295 mount-trans 70+ E Body, 71+ B Body, 69+ C Body, F Body $40.85
2579804 nameplate-"383 4 BARREL" fender $35.90
3445223 nameplate-deck lid "R/T", stick on Challenger $41.60
3505490 nameplate-door "ROAD" stick on $20.75
3505491 nameplate-door "RUNNER" stick on $23.95
3444938 nameplate-fender "CHALLENGER" emblem $34.60
3680304 nameplate-fender "DUSTER" 72 & up $32.70
2579443 nameplate-fender "FORMULA S" $29.85
2998804 nameplate-hood "440 SIX PACK" $33.50
2998800 nameplate-hood “426 HEMI” $47.85
3443247 nameplate-hood "340 FOUR BARREL" $39.35
2998802 nameplate-hood "440 MAGNUM" $35.00
3443516 nameplate-hood "440 MAGNUM" 1971-74 Charger $32.15
3443159 nameplate-hood "CUDA 340" $31.70
2901812 nameplate-quarter panel "R/T" 69 W,X $36.85
3505419 nameplate-quarter panel"DART", trunk or fender $23.50
2841886 nameplate-roof"CHARGER" 1968-70 $32.10
53020185 nipple-A Engine bypass hose screws into manifold $5.10
6030979 nut-adjusting-clutch rod $3.45
4520061 nut-chrome-remote control mirror door panel $5.45
1622536 nut-for battery terminal bolt $1.75
J0120375 nut-for throttle bracket clamp $2.45
4041150 nut-long B-RB exhaust manifolds $5.25
6026292 nut-outside mirror attachment $4.60
2806982 nut-short exhaust manifold for B-RB engines $9.20
6030607 nut-throttle bracket for throttle cable retaining bracket $2.95
118614 nut-wing air cleaner nut $0.70
J3151735 nut-wing,battery tray holddown stud 67-69 all models $2.25
6032619 nut-wing,spare tire $6.20
6025413 nut-wiper motor mounting use 3 $2.85
- Dave-R
6035709 o ring-speedometer pinion housing $2.45
6030608 o-ring-transmission oil fill tube all automatics $2.25
3575101 pad-automatic trans rubber brake pedal 68-70 B-body $7.10
4049699 pads-brake, cop car disc with slider calipers $61.55
52118802 pan-trans 727 AT, standard capacity $47.35
6022891 pin-door hinge $3.95
3671447 plate-block off EGR 6 cyl $5.00
2424864 plug-floor pan 1-3/4" hole $3.00
4780194 plug-floor pan 1" hole $2.50
6029939 plug-floor pan 1/2" hole $2.50
2483571 plug-floor pan 2-1/2" hole $4.45ea
2811825 plug-rubber clutch rod hole in cowl-all models $0.35
2860332 plug-rubber-antenna hole in cowl-all models $2.00
R3643333 power steering box $277.75
3870074 pulley-crank B-RB engine w/ A/C & pwr steering $139.00
3751613 pushrod-fuel pump B-RB engine $23.25
2260787 pushrod-wheel cyl, 2/wheel all drum brakes $3.25
1686198 radiator-petcock/drain, a/m $4.20
5234625 regulator-voltage 70 up, all models $36.25
3738109 relay-horn w/ buzzer 70 up, All models $12.00
2889565 relay-ignition lamp time delay $11.85
4638260 relay-starter 70-74 A-B-E body $16.85
1730095 retainer- ring-fuel float ass'y a/m $6.60
1945473 retainer-B-RB engine aluminum rear main seal $58.70
2983017 retainer-drive link to crank arm 2sp wiper all 71+ BJRWXPDC models $2.60
2823845 retainer-for wheel dome 3580466 road wheel $9.00
2206925 retainer-front shock bushing, this is the washer $1.95
2583377 retainer-ft door lock All V,L models, 68-70 R,W,X,P,D,C,Y models $2.70
2401910 retainer-torque shaft bearing holds bearing in place(clutch part) $8.20
6023546 rivet-window to regulator $2.85
2534240 rod-A engine clutch release Fits 70B/E body $47.10
3467235 rod-clutch release B-RB motors fits B/E Body $36.95
2950852 rod-shifter E body 1-2 gear 4 speed; rev-1 gear 3 speed $62.00
2950853 rod-shifter E body 3-4 4 speed; 2-3 gear 3 speed $54.35
2468849 screen-oil pickup, A engine $40.20
2899808 screen-oil pickup, B-RB engine 5 quart pan $38.45
52070427AA seal-axle 8.25 $10.25
2265942 seal-clutch torque shaft bearing 2 req all models $6.60
3794032 seal-cowl top drain hole HNFG $2.60
3404451 seal-fuel tank float ass'y all models $1.25
2801692 seal-input shaft oil manual trans $5.35
2404216 seal-outer axle 8.75 axle $10.35
4531216AB seal-output shaft A-833 4-speed, 727 $13.85
2400163 seal-output shaft Manual trans A833 2-1/2" yoke $22.85
J8130157 seal-pkge input shaft Saginaw steering box $17.15
3418658 seal-shaker hood $112.00
1947708 seal-spark plug tube 6 cylinder engine $4.60
3488609 sending unit-oil pressure gauge, all models $94.00
4504202 sending unit-temperature gauge all models $13.20
4169629 sending-unit oil pressure light $5.70
2875604 seperator-spark plug wire 4 wire A engine $2.10
1841499 seperator-spark plug wire 4 wire free standing $2.35
3755972 seperator-spark plug wire A engine 75 & up $2.10
4028123 shaft-counter A833 Manual Transmission $42.70
2808579 shaft-package lwr control arm B/E Body, includes bushing $45.00
2951347 sheild-spark plug heat B-RB motor $16.93
4130503 shield-dust,A engine 727mounts with starter $11.45
4140724 shield-starter heat, all models with round starter $32.20
3515920 shield-torque converter case 727 automatic w/ A engine $32.85
4019122 shifter-HURST 4-speed $289.00
4147350 shifter-knob, AT column shift, all models $7.60
4057093 shocks-police car front, fits all F,M,R bodies G0073504 $30.35
4057094 shocks-police car rear, fits all F,M,R bodies G0073482 $30.35
2998326 shroud-26" radiator fan 70+ B,E bodies $89.95
2785434 shroud-radiator fan-26 inch 66-69 B Body $89.85
2879600 sill plate-70-74 E body $59.25
3416002 sill plate-71+ B body $59.25
4397809 sleeve-heater hose, for all models w/ AC usually small blocks $5.10
3410700 spacer-transmission mount all models $7.10
2643705 spring-clutch release fork return all models $6.20
2935375 spring-hood release, 70-72 all models except 70 W V L models $3.45
4773942 spring-parking brake lever strut, inside brake drum 11" brakes $2.00
2073687 spring-retains throwout bearing to fork-uses 2 $4.10
3583020 strap-battery 72+ B body 73-74 E Body $61.35
3404404 strap-battery all 70-76A 70-74B 70-74 E bodies $15.60
1828352 strap-battery holddown 63-69A, 64-69 B, 68-73Y $16.95
2258862 strap-ground strap fuel tank sending unit a/m $9.10
3454485 striker-door all models $22.75
1826286 stud-air cleaner, all 4bbl carbs $11.75
2074089 stud-battery hold down short/inner side $5.00
2534814 stud-battery hold down,outer long A body63-76 B body 70-74 $6.10
3418900 stud-throttle cable-automatic trans $8.35
3418899 sutd-throttle cable- manual trans $8.35
4419337 switch-A/C cycling-rotary compressor 1978-81 $50.25
4373814 switch-back up lights MT $13.50
2947798 switch-cruise control brake A B E C Body $33.60
3747092 switch-ignition 70-74 E body, 70-76 A body, 70-74 B & C body $61.60
2926275 switch-stop light, heavy duty, C & Y body $30.35
2947801 switch-turn signal 66-69 A body $53.35
4293102 switch-turn signal assy; 1970-76 A, B, E, C bodies $50.10
3746530 switch-wiper, 2 speed, 71-73 P, D $48.00
55054788-9 taillights-ramcharger rt/lt with black trim $58.60
3404492 tank-gas 68-70 Charger $305.00
4002006 tank-gas strap j-bolt all models $24.20
53021195 tensioner-A engine timing chain $34.00
3418459 thermostat-195 degree, all models up to 1978 exc 6 cylinder $10.95
2538926 thru 2538945: speedometer pinions all models 1966-75 $14.60
2925322 tray-battery 70-73 E & 70-72 B Body, 72+ B body $31.70
3642999 tray-battery 69 B body $45.00
3642334 tray-battery A body 68-76 $23.95
4490364 tray-battery HNFG $38.95
4020181 tube-automatic trans fill/dip stick A engine $27.75
1859788 tube-dipstick 64-69 A engine $12.00
4027249 tube-dipstick A engine 1979-1981 $9.20
3418933 tube-dipstick A engine 318/340/360 up to 1976 $10.75
3462416 tube-dipstick B-RB engine 1968-9 $10.75
3462415 tube-dipstick goes inside the exhaust manifold B-RB HP 70-71 $34.10
4173223 tube-extended oil filler, requires 6030608 cap and seal $27.25
3878967 tube-fill AT, B, RB engine $31.35
3679255 turn signal-fender mounted chrome cover/lens 72 & up $10.45
4339457 valve-water heater control all models 1979-81 $43.25
2124715 vent-manual trans and rear axle all models $5.25
1618732 washer-cam bolt-A engine $3.75
53010091 washer-exhaust manifold A-engine, slant 6 $2.00
1319555 washer-inner rear shock bushing a/m $0.95
J4001104 washer-manual trans gearshift rod swivel to shifter $2.95
1319554 washer-outer rear shock bushing a/m $0.20
2405086 washer-plastic anti friction clutch linkage $2.10
2405085 washer-U shaped metal retaining spring for clutch linkage $3.00
J120393 washer-used w/ 6026776 clip-kickdown rod to throttle stud $2.35
3780127 water pump-all B-R/B engines w/ A/C & 426 Hemi $93.25
3780196 water pump-all B-R/B engines w/out A/C $154.00
2932230 weatherstrip-vent window channel 68-74 A & 68-70 B-Body $37.35
3461458 wheel-rallye center 72-74 A body $62.35
3461066 wheel-rallye center, lg bolt pattern Dark style-color $78.95
3580466 wheel-road or Mag 500 center dome $51.70
2809013 windshield-washer pump electric 70-74 E body & 70+ B-body $39.75
2889803 windshield-washer reservoir 1967-70 B body $30.95
3431074 windshield-washer reservoir 1970-71 E Body & 71 B body $36.60
3431590 windshield-washer reservoir 1972-74 B & E body $43.25
2809011 windshield-washer reservoir 67-76 A body variable speed $37.00
3431154 windshield-washer reservoir 70-73 P, D, C $36.20
2983067 windshield-washer reservoir 70-75 A body $39.60
3431975 windshield-washer reservoir filter all models $3.45
4467339 windshield-washer reservoir HNFG $30.95
2811263 windshield-weather strip 68-70 B-Body 2 dr exc convert $156.00
2895870 windshield-weatherstrip 70-72 V L fastback only $132.00
3879325 windshield-wiper cam release pkge-parking-2 speed all models $28.50
2822261 windshield-wiper limit resistor, 2 speed All models $14.20
2497502 windshield-wiper washer reservoir 1968-69 A body 2 speed $32.20
3799422 wiper-arm assy lt side, XJSET 1979-1981 $42.25
3431727 wiper-arm, A body rt or lt $27.50
3799447 wiper-link assy XJSET models $51.50
4339405 wires-spark plug B/RB-orange color $65.25
4339404 wires-spark plug,-A engine $51.85
2852323 yoke-trans 727/833 trans small U joint $124.00
4384437 yoke-trans 727/833 trans large U joint $159.00
