alternative O/S help or win 98
we've had a very old laptop sitting doing nowt for a few years
Inspiron 7000 400MHz 64 meg ram
2 years ago we tried a xp instal which failed, screen turned off with 34 minutes to go
Long story short.... my 3 year old grand daughter found the damn thing and it's now "her" computer
I finally figured out the problem with the XP install, needs to be plugged into an external monitor while installing, xp pro now installed which isn't no mean feat considering
problem is it's soooooooo slow, took a look at Unbunu, downloaded and burned to cd, I cant get it to work ( no internet connection)
Q is.... anyone point me in the direction of a Linux download that will actually work (needs to be very light but with a good interface)
Or need a win 98 pref SE with product code
of course our win 95 and win 98 went in the bin when we got XP Prof
would like to try something other than Bananarama! MS
:help:
forgot to say after MS i'm a little lost with this Linux
doesn't seem to be fire it in the cd drive and away ya go
found it kinda funny that the download for ubunu was 715mb and a cdr is 700 if you're lucky
PMmmmmmed
Linux of the vintage you are talking about is a command line operating system.
you will need to know about disk partitioning to do it
standard linux install uses about 4
you then need to get K desktop or similar
i.e the process is like builidng a DOS PC from scratch
updating it with windows
and then office.
but more complicated
the Plug and play linux distribution idea is recent i.e last 3 or 4 years and hence they tend to only run well on recent hardware
i.e even modern versions are not that "point and click"
you no longer need to be a skilled UNIX admin to do the job but it aint windows
Thanks for the reply Dave
As it's for a 3 year old I'll forget the Linux deal for a while then.
Did fancy the idea of getting her used to something that wasn't MS
Backburner on that for a bit
Replied to your PM
Neil :thumbright:
Prothed
Post by Prothed »
There is a whole range of Linux distributions around and some are certainly capable of running on very low-end systems - but it's going to take so much time and effort... and then you have to find Linux applications...
Get a copy of Windows 98. Available from an internet near you, or ebay for 99p.
Daves sending me Win 98
top man.... :thumbright:
Prothed
Post by Prothed »
Good. Helpful people these Daves.
