Valve stem seals
Valve stem seals
Posted in workshop, but asking in here for help from the non-workshop-readers! :thumbright:
Bit of a mystery with the valve stem seals. Got two bags of different types, 8 only of each, one larger than the other. What do these normally look like for a 318? What's with the different types? These were gifted, so I don't know where they came from, but they were supposed to be s/b.
Decided last night to use the smaller grooved ones for the exhaust valves and the larger smooth ones for the inlet valves. Seemed a good idea at the time, but now in the cold light of day without coffee, want to be sure...
Please don't tell me that's something else that needs to be ordered...
Guy
Post by Guy »
one set for exhaust valves and one set for the intake valves :thumbright:
Stu wrote:Decided last night to use the smaller grooved ones for the exhaust valves and the larger smooth ones for the inlet valves. Seemed a good idea at the time, but now in the cold light of day without coffee, want to be sure...
So have I got it right, then? :)
Guy
Post by Guy »
I am buggered if I can remember now Stu, but I think that the grooved ones go on the intake as they fit over the valve guide to stop oil being sucked in, but as I said I cant remember the last time I used OE type of valve seals.
Well that was the other thing, these don't seem to fit fully over the valve guides. :-k Wasn't sure if they would press over when the springs went on? :?
TyreFryer
Post by TyreFryer »
Guy's right Stu, the ones with the ridges should fit tightly over the intake valve guides and the thick ones go on the exhaust valves. They just float on the valve stem.
Martin Walker
Brilliant, cheers Martin. :thumbright:
That's how they went on, but didn't want to force them down without checking. :read2:
Thank's Chaps. 8-)
TyreFryer
Post by TyreFryer »
Have you changed them since your first post Stu, according to that you fitted them the wrong way round?
Martin Walker
Nope! Just changed my memory! :tongue3:
#-o
Well what do you know? Had it right after all... Just had a bad case of ferkwit-itis when it came to remembering! :roll: :D
