http://home.comcast.net/~loudgpz/GPZweb ... oints.html
this man is a clever chap
check his home page for other bike related stuff
circuit 4 allows you to use an HEI module on a car with points
granted circuit and remarks about coil primary resistance are aimed at bike and scooter owners with RPM ranges way out of car league
but circuit 4 eminently suitable for a mopar with orginal points dizzy (have a better advance curve in some cases)
junk the ballast and run a modern ford or GM external frame coil
points will last 1000s of miles more. contacts won't wear out
throw them away when they loose their springyness
obvioulsy if you bypass the circuit to run on points you will weld em
electronic igntion for points only cars
