How do i convert my reverse lights to indicators?
I've been looking at wiring diagrams al morning, but does anyone have a handy guide on how I can split off the indicator wiring from the tail/stop lights and run it to the reversing light bulb so I can get legal indicators?
Car is a 73 Roadrunner.
Adrian Worman
Post by Adrian Worman »
There's Bananarama! all to it miles
Just locate each indicator wire from both tail lights with a test meter and simply disconnect them, then disconnect the rev light wires and replace them with the ind wires ;)
Jesus built my hot rod
72 Challenger
65 Barracuda
ANTON
Post by ANTON »
The easiest way is to run a new wire from the brake light switch to the brake lights and then swap the brake light wires to the indicators and then you don't alter any of the original wires.
All the original wires to the rear of the car go through the steering column and headlight switch so it is best not to mess with them.
www.apdautomotive.co.uk
APD Automotive
22 Willow Lane
MITCHAM
CR4 4NA
0208 6400729
AllKiller
Post by AllKiller »
Or cheat and run wires from the fron indicator fed to the rear reverse lamps...easy
And ive not done this, but if you used a stop and tail bulb in an appropriate holder in the reverse light you could keep the reverse lights as well. :thumbright:
ALL KILLER NO FILLER
Adrian Worman
Hey good cheat Steve ;) ............ I'd consider using yellow LEDs inside the reverse light housing, they are super bright and show their colour thru most any lens :thumbright:
72 Challenger
65 Barracuda
Thanks guys, that provides a solution.
Next up..no indicators. Separate thread!
AllKiller
Post by AllKiller »
Adrian Worman wrote:Hey good cheat Steve ;) ............ I'd consider using yellow LEDs inside the reverse light housing, they are super bright and show their colour thru most any lens :thumbright:
Would be a good cheat Ade... if i had put you need these bulbs to do it :thumbright:
http://www.ebay.co.uk/itm/310405103936? ... 1423.l2649
Those are mental, but so is the price. Orange bulbs and/or orange tape on the white lens for me.
AllKiller
Post by AllKiller »
Pm me your address I have just the thing for that lens colouring job Miles
for LEDS
you need one of these
http://www.amazon.co.uk/s/?ie=UTF8&keyw ... 6pmno0vc_b
5050 (bright) or 3528 (less bright) water proof strip
a soldering iron
a pair of scissors
your old bulb with the glass smashed off so you can solder to the filament support
http://www.ebay.co.uk/sch/i.html?_trksi ... &_from=R40
I used yellow strip inside the reverse light and it looks good, the reverse light is still in place and working too.
Ran a new wire for the brake light as the indicator wiring is more complex that the brake wiring.
It passed MOT (so it must be legal)
Hi Jon, sounds similar to what Anton suggested. I can't remember as I'm not with the car, but is it the case that the one stock wire carries current for both indicators and brake circuit, hence running a separate wire for the brakes being a better solution?
Adrian Worman
Yeah you'll have to split the tail/brake lamp circuit from the indicator circuit or you'll still have flashing brake lamps!
Just run a new wire from the output side of the pedal switch under the dash to the rear of the car like Jon did :thumbright:
72 Challenger
65 Barracuda
Just to return to this and bear with me for being thick...but looking at this diagram
http://www.mymopar.com/downloads/1973/73SatelliteB.JPG
...can I not just use the brown/green indicator wires and just re-direct them to the reversing lights (back up lights on diagram)as a feed as initially suggested by Allkiller/Ade? I ask this specifically as Anton and Jon seemed to thnk it necessary/correct to re-wire from the brake lamp switch and I cannot see why :oops:
If I'm missing something please feel free to school me :?
Jon
Post by Jon »
if you don't rewire from the brake switch, doesn't turning the indicator on switch off the brake light on that side?
think that's how it works on mine...
