brake unions
paolo_mangusta
brake unions
Post by paolo_mangusta »
Does anyone know a source for the brake unions that go into the distribution block (70 Dart)? I can only find the usual British types that have the unthreaded bit on the end so won't engage enough threads in the block :-/
Cheers
Paul
'64 Barracuda
I got mine from WASP
dustymopar
Post by dustymopar »
Paul, Kris Brown would supply those www.popbrowns.co.uk
Also, if I remember correctly, some Volvo's use the shorty's as I bought some on Ebay a couple of years ago - maybe worth a quick search ;)
ANTON
Post by ANTON »
I use the british type and cut the unthreaed bit off and the use a drill bit to drill the end and job done.
www.apdautomotive.co.uk
APD Automotive
22 Willow Lane
MITCHAM
CR4 4NA
0208 6400729
paolo_mangusta
cheers chaps, will try those options - I had looked at modifying one Anton but was concerned about getting the taper angle right, good to know you've done it without problems
'64 Barracuda
Automec in buckingham. Will supply everything off the shelf. Got complete set of all fittings for my charger. They will even make the kit up for you if you need. :thumbright:
jerry
Post by jerry »
Adrian Worman
Post by Adrian Worman »
I got a box of em Paul, how many do you need? :thumbright:
Jesus built my hot rod
72 Challenger
65 Barracuda
