Half shaft bearing number ?
Can anyone tell me the correct Timken number for an 8 3/4 tapered half shaft bearing.
Think I may have been mis sold the wrong ones.
TIA. :thumbright:
Anyone ???
Plenty of kits available from both Yukon and Timken but no numbers. !
Johnny Dart
Post by Johnny Dart »
Mossy68 wrote:Anyone ???
This might not help , if you are trying to get the new bearing before you remove the old one :roll:
Most all bearings have the sizes stamped into the race and roller. Once you have them, you can contact your local bearing supplier, for a match.
There must be loads of suppliers on USA eBay, that's where my new ones came from. £4 USA, $49 - £80 UK.
Thanks JD , but I already have the bearings but come up as a manual gearbox bearing ! Maybe the same ? Therefore the question.
Timken M201011 is what I have ?
Johnny Dart
Sorry,misunderstood the question a bit :roll:
This is the sizes of an 8 3/4 axle half shaft bearing.
Johnny-
The RP400 Bearings have the following measurements:
- 2.875" OD
- 1.565" ID
- 1.140" Height
I know you still don't have a Timken part number, but you can measure them , and see if the size is the same. :thumbright:
Johnny Dart wrote:Sorry,misunderstood the question a bit :roll:
Johnny-
- 2.875" OD
- 1.565" ID
- 1.140" Height
Cheers JD. :thumbright:
Part number comes up as manual trans output bearing?
Cup and cone are M201047 /M201011. Which comes up as Timken set 7.
Which is also for axle.
Does that sound right ? :?
( havnt had chance to measure the ones I have )
According to My Mopar website.
1958to1969 Dana Power lok suregrip 741/742
Timken cone 25590
Timken cup 25520.
Now I'm lost :?
Oh this is for my blown and injected Hemi 71 Duster project I've kept quiet and NOT a more door !!!!!! :D
Looks like I'll have to get the vernier out then !
terryr
Post by terryr »
take the old bearing or part number to a bearing shop ,that number probably goes in many things ,not just automotive ,or they can crossmatch for a different make ,cant remember the last time I bought one from a car supplyer ,I just go to the bearing shop ,also good for v belts and drive belts ,and half the cost
terryr wrote:take the old bearing or part number to a bearing shop ,that number probably goes in many things ,not just automotive ,or they can crossmatch for a different make ,cant remember the last time I bought one from a car supplyer ,I just go to the bearing shop ,also good for v belts and drive belts ,and half the cost
Cheers Tel. :thumbright:
