Brake bleeding issues
fin170703
Post by fin170703 »
Morning All...
Having changed the rear cylinders and shoes on my '73 roadrunner, I'm scratching my head a tad in regards to bleeding the system through
Has anyone got the correct procedure please ? I can't honestly say I've ever done it, so am probably going about it all wrong !!!!
I have the cover off the master cylinder and have cracked the rear bleed nipple. when I put my foot down on the pedal, something shoots brake fluid out of the master cylinder and all over the place ! with the cover on, I'm getting no fluid through what so ever, and I've tried both sides !!
someone help a pleb out please
get a mittyvac
pull the bleed stud out of the cylinder
wrap thread in Teflon tape
put it in and then back it out a smidge
open master cylinder
top it off
connect up mitty vac
remember that the lid has 2 connectors
the 1 that goes to the bottom of the reservoir goes to the bleed nipple
start pulling brake fluid through until its clean and any bubbles are not coming from the flow out of the nipple
lock it off
top up master cylinder
do the other side
try brakes
top off master and repeat until peddle is hard again
you may need to just connect the pipe to the nipple and not use one of the rubber couplers
mitty vac instructions are not the best
pip to plastic cup
pipe from inside lid to bottom of cup
pipe from other lid connector to gun
clean it out when done
fin170703
Post by fin170703 »
I'll have a search for a mittyvac,
Can it be done without, or is it just a much easier process with one ?
Thanks loads for you help Dave, appreciate it
I use a hand vacuum pump and 'suck' the fluid thro, found this method much more successful than pumping the pedal or 'eezibleed' devices
Something like this
http://www.ebay.co.uk/itm/Hand-Vacuum-P ... 2055801582
fin170703 wrote:I'll have a search for a mittyvac,
great for 1 person work
if there are 2 of you and one of you has bleed brakes before
its a case of push the peddle and lock off the bleed nipple when the fluid runs clear with no bubbles on the down stroke of the peddle
or cracking joints further back with the nipple at the cylinder closed to purge air out in between
but for 1 man job mitty vac works ok
fin170703
Post by fin170703 »
Thanks Gents
fin170703
Post by fin170703 »
I've got someone helping now, whos bled brake before
The fronts bleed no problem and when I build up the pressure in the pedal, and crack off the caliper bleed nipple, the pedal goes down to the floor (as youd expect) The problem is that I have a solid pedal even when I crack off the bleed nipples for the rear cylinders !
confused.com
I have had a rear hose collapse internally such that I could take the rear drums off and still not get the slaves to move - that one does your head in!!!
fin170703
Post by fin170703 »
I'm pulling my hair out pete
Fronts bleed perfectly but I cant get anything through the rears, I just get a squirt of fluid into the air ,from the master cylinder, and the brake pedal goes hard as a rock !!
I don't get it at all, they bled fine last week before I changed the rear shoes / cylinders
yes that is because the rears have been shut off totally by the danger burst pipe in the brake system switch.
its in the master cylinder or Distribution block up front
you have a safety/ danger switch in the system
if pressure is unequal between front and back the low side gets switched off
its a piston based thing that sits under the place where the brake failure light wire goes either into master cylinder or into the distribution block
you reset it by undoing the collar on the wire connector bit and allowing the break failure light switch thing move out until you hear a TOCK then you do it up again.
when it is blocking off one or the other circuit there should be a light on the dash. but many have had the bulb blow
this DANGER switch was used on cars from the very late sixties onwards.
Take a picture of your master cylinder and distribution block and we can all have a crack at pointing you to the thing. they all look a bit different
but if a wire connects to a spade or bullet its the other end of that thing that locks the piston and is keeping your rears off
I ran around for 6 months with the rears off and didn't know when I first got the car. my glowing bulb had been taped up behind the cluster to Aid with sale of the car to me
NICE.
fin170703
Post by fin170703 »
That makes sense Dave,
The actual sensors wires are not connected but I guess this is a pressure based system that gets activated by un equal pressure ?
I'll give that a go now
Got it in one
undo that's switch's collar and pull it out 1/4 to 1/3 of an inch.
wire either never connected
taken off the last time the brakes were bled
or disconnected years ago to get the dash light off, I'm not casting aspersions I don't know who owned it previously, its more likely error than devious practice
keep in mind that you may need a full rear circuit master cylinder full to fill the pipes to the back
top off again before bleeding
and yes it will fountain up from the master a bit especially if there is lots of air pushing back
fin170703
Post by fin170703 »
I'm thinking its the top connector, roughly in the middle ?
fin170703
Post by fin170703 »
pulled it completely out and its a plastic connector !? not sure if I have the right bit
My mates dicking around with it as I type
anything without a pipe
but looks like it might have had a wire to it
basically the metal piston when locked in the Block off a circuit position
also earths the wire from the dash light and makes it come on
so a lump for a connector and a switch is 99% of the time the one you want
the piston is dumbbell shaped when it shuttles to one end the fat bit at that end blocks off the circuit and the fat bit at the other end gets locked by the end of the switch so it stays in poistion
