Exhaust Manifold Gaskets.
I am after a good quality pair of Exhaust Manifold Gaskets to fit a 383ci with Headers in my 1968 Dodge Charger, can anyone recommend what to use please I have used Mr Gasket in the past but they don't last long.
1969 Dodge Coronet SuperBee.
1968 Dodge Charger.
1969 Mercury Marquis 2-dr HT.
1994 Ford Mustang GT V8
2003 Audi A4 TDI Estate
2005 Ford Transit
1968 Dodge Charger.
2005 Ford Transit
Re: Exhaust Manifold Gaskets.
Percys Gaskets......
Used these after they were reccomended in the US on my SB with Dougs headers. They do a BB version:
https://www.summitracing.com/search/pro ... ine-family
Tried all sorts. Never had one seal properly yet ! (tickticktick)
Tried TTi, no-names, currently on sort of a layered-aluminium affair (cant remember who made it). Got some copper ones to try next. I've stopped worrying about it.
Current Charger status - "Working !"
these work
and can put up with 2-3 removals and re use
https://www.pentastarparts.com.au/store ... ail&p=1299
Interesting.
I put it down to the sheer weight of the headers and the naffness of the access to bolts to get any real leverage. It just has so much downwards pull that it never seems to achieve even distribution. Run it long enough the soot plugs the hole anyway.
Percys have always worked for me. There is an issue I have come across on big blocks that prevent good sealing. The area across the exhaust ports is machined flat which leaves a ridge above the ports of varying height. Some headers on some heads can contact that ridge along the top of the flange and stop the header pulling up square when you tighten the bolts. Always check for that and a bit of a bevel on the header flange is all it takes to clearance it.
Thanks for all the input Lads it's much appreciated.
1968 Dodge Charger.
2005 Ford Transit
1968 Dodge Charger.
2005 Ford Transit
Bought some Maxx copper header gaskets with o rings does the raised ridge around the ports face the engine or away from it and which side do the o rings go.
