I am planning the Aussie Charger strip down and rework. I need your advice and help to make the right decisions for the car. When we have come to the best solution I will go after that and follow it through.
My current ideas are:
Front: AlterKation kit including the Willwood discs, rubber engine mounts to insulate vibration.
http://www.bigblockdart.com/alterktion/ ... ion2.shtml
Rear: undecided yet but leafs with watts linkage is a possibility. I want the car to take a Pro Touring stance and to be able to handle accordingly. There is no reason why a light (2700 lbs stock), 99" wheelbase muscle car can't run rings around all but the most up to date supercars. I really want to keep a solid axle for strength and an 8 3/4 conversion with 3.91 ratio and a posi is my current thinking. I definately want rear disks and as stronger setup as possible.
Engine: 360 stroker (408), looking for somewhere in the region of 500hp. Ally heads, cam, rods, high comp pistons etc. This can really be decided later as it will be the last bit to be done after the body etc. We could even build the motor after the car is back on the road and run a stockish 318 for a while first.
Trans: Initially I was taken with Dave Robsons work on the 6 speed but ultimately it will beat me I think (financially aswell as mentally). Then I looked to some of those big Jerico trans but they are way too expensive and quite high maintanence. Since I didn't really want a traditional A833 I have arrived at this.
http://www.keislerauto.com/mopar/transm ... _67-76.asp
I am looking to put in frame connectors and possibly a roll cage (please advise accordingly). I want a car that looks mean but understated if you get my meaning. I want a full interior and to retain as much of the original styling as possible. Obviously modern wheels are going to have to be used to obtain the handling characteristics I want but I don't want rubber band 19" boy racer wheels, I want ones that fit and do the job, I was thinking somewhere in the region of 16" with 40 or 50 series tyres.
Body: Stock as possible but the idea of a fibreglass hood and trunk lid is there. I'm not sure about other glass panels yet, and I want to keep glass windows really. It is essentially to remain as a street car and an easy MOT is preferable (with the exception of volume!)
I will spend money but as I am a student it is a function of time. So any mega expensive bits like the trans and the front frame etc will be worked towards. Hence it is a longish project. The main thing is quality and reliability. I want to do as much work as possible myself (pretty much all of it) but I will need some help from time to time (most of the time come to think of it).
So guys advise away and lets come up with a plan for an awsome car. I am going to the nats if some of you want to sit down and draw up some plans with me?
