Heat crossover blocking
Considering doing this whilst I have everything apart, if not for any better reason than to try and get rid of the starting issues I get in the heat, which I’m assuming is vapor lock / fuel percolation issues.
Talk to me about methods and madness, please!? :read2:
2001 Dodge Ram Van
Re: Heat crossover blocking
Shim steel or aluminium, to block both transfer ports off on the heads - Blue will be along in. minute....
Yes a piece of thin shim steel stuck to the head to cover the heat crossovers with high temp RTV before you fit the gaskets will do it.
Yes, if I’d thought about it that’s what you did on the Polara, isn’t it? :-k
Best see if I can find a supplier of shim steel close, then. :thumbright:
Ta both.
2001 Dodge Ram Van
Blue wrote: Thu Mar 30, 23 4:34 pm Yes a piece of thin shim steel stuck to the head to cover the heat crossovers with high temp RTV before you fit the gaskets will do it.
Out of interest, do you know what sort of gauge you use? Looking on eBay to get some and varies quite a bit. Ta. 👍
2001 Dodge Ram Van
About 8 thou. ought to do it.
Magic, ta. :thumbright:
2001 Dodge Ram Van
