Progress
Progress
Just so you don't think I've been slacking over the winter here's some of what I've been up to. bought a used set of Caltracs and monoleafs a couple of years ago from Tweety, and finally got around to fitting them in place of the inboarded superstock springs I'd originally fitted back in the '90's. Had a few issues to sort anyway so I decided to do it all in one go. The diff gasket was leaking as was the rear fill plug on the back of the case. I welded in a new one that has a proper O ring seal so that should fix that. The back brace was beating up the Rancho shocks when cornering, the only way I could see around that was to move the shocks in front of the axle, which meant I had to make a new tubular shock cross-member, no big deal, I also decided to mount the shocks close to vertical to give more consistent damping. When I originally inboarded the springs I had the rear shackle mounted through the chassis rail. this doesn't allow a great deal of suspension movement before the spring eye hits the bottom of the rail. I decided to fit a set of sliders instead which offer more travel and more positive lateral axle location. This is how all the fast leaf spring cars in the States seem to be doing it now. I did have to get the rear eye of the monoleafs re rolled to standard Mopar size because the original eye size is huge and way too big to fit in a slider. I wanted to get this done before the next motor goes in, which time and money permitting will be for this season. looking forward to getting this down the track again!
- latil
Top job
I didn't realise the spring eye was retained for the slider,had visions of a lorry set up with a flat leaf in a box with no restriction on travel.
Steve, the Caltracs work like a cross between a traction bar and a poor mans four link. The lower bar makes the front section of the spring solid eliminating wheel hop, it also uses the turning force of the axle to propel the car forward like a four link does. Jerry, yes the back brace is that lump across the axles Width. It's there to stop the axle case bending (it's only sheet metal after all) like a banana which happens when you put a lot of power through them. Our very own Dennis the Menace managed to bend his axle last year...
- Cannonball
