A big Carter mechanical will need a regulator as well. They put out more pressure than the carb will like.Gringo wrote:If I do any more tuning work at a later date, whether it be different heads/carb/cam, what are the limitations with a mechanical pump? I'm assuming once I start chasing big horsepower I'll need a leccie pump, or is a mechanical pump up to the job?
