Steering Wheel Play
Is it just the wheel moving or the whole column?
Jon
Post by Jon »
have the bolts fastening the column to the dash come loose?
Holly
Post by Holly »
That ain't normal, Bilco!
Sounds like the steering column top bush is either shot or whatever holds it in place on an E body has come loose. A bodies have a sort of wire snap ring either side of the bearing to hold it in place, and when that comes out of it's groove it's slop city. I would imagine your column uses something similar. You need to get the wheel off and then you should be able to see the problem.
