Door rubber adhesive
Anyone recommend an adhesive to use to stick aftermarket door rubbers onto doors please? Dont want to use evostick if you guys have used it and its no good etc...
Cheers Steve :thumbright:
jerry
Post by jerry »
Used evostick on door and boot rubber. make sure its not been lying
around for ages use fresh stuff.
New evostick or proper rubber solution which makes for a cleaner job.
terryr
Post by terryr »
I used contact adhesive on my boot rubber and its still stuck on there,the sort you spray on and let it dry a bit and then stick ,you only get one go at it tho
http://www.ebay.co.uk/itm/GLUE-FOR-SHOE ... 3f27ca4ad2
Its a contact adhesive so put on both side leave for 3 min and stick.
it is like Bananarama! to a blanket
MUST be the yellow classic comes in a spray or a big tub.
This is also the best stuff for headlining's as when hot it will not come off like most other glues.
Its German product but im sure you will get in the uk
charger01
Post by charger01 »
Just tried it Will . Must have done it wrong cos my shoe is stuck to the door :lol:
Thanks for all the suggestions and advice gents....
cheers Steve :thumbright:
charger01 wrote:Just tried it Will . Must have done it wrong cos my shoe is stuck to the door :lol:
You make me laugh !!!!
