oil for manual steering box?
what oil do you use in a manual steering box? & how much? cheers :)
I though it was just full of grease :shock:
Mah book sez Multi purpose gear oil MIL-L-2105B also says you can use Sure Grip lube. Oil should just cover the worm gear.
cheers everyone,I`ve got some suregrip oil,I`ll use that :D
Multi purpose gear oil SAE 90 as defined by MIL-L-2105B. That includes Chrysler Hypoid (PN#2933565) and Sure-Grip Lube (PN#2585318).
I read in one of the Stateside Mopar mags a while ago the factory used a combination of gear oil and grease, they heated it all up and while still liquid poured the mixture into the steering box, when it cools it thens solidifies to a certain extent. The trick obviously is getting the boiling oil into the small hole in the box before it hardens, not an easy task, I know I tried it !
The manual mentions packing the ends of the worm with steering box lube as it is rebuilt and then topping up with oil.Can't find a ref to the lube though ie what type of grease?
When I checked it ,it was full of grease :shock: so I suppose I`ll be leaving it as is :!:
