Wheel alignment?
It could be a siezed caliper on the left front . If the caliper is dragging slightly it would cause the car to want to steer left when driving straight but when the brakes are applied you get no movement fron the left caliper and the right one does all the work causing the vehicle to steer right. Get the car down to an MOT station and put it on their brake rollers they will be able to check how much bind there is. HTH
- Dave-R
What Guy said.
But also!
The steering on these cars has often been messed with.
It is important that the steering box is centered exactly (turn to turn) and then the steering and front wheels all centered by adjusting the track rods.
If the steering box is not centered when the front wheels at pointed straight ahead you get a lot more play in the steering and the car will wander more.
But also!
- Dave-R
That is a good price as long as it is a good quality re-print as the same thing on cd-rom is $70 from www.moparmanuals.com
