Carb setup vacuum
CRAIG
Carb setup vacuum
Post by CRAIG »
Morning
I cant seem to increase the vacuum when I adjust the two screws on holley carb.
Car is warm, and in drive with dizzy disconnected. My vacuum gauge doesn't move hardly at all.
Ideas
1969 Dodge Charger
1972 Chrysler Hardtop
I assume you are talking full manifold vacuum not sparc port?
CRAIG
Post by CRAIG »
Yes bottom port. No vac at all at top one.
1969 Dodge Charger
Have you tried bumping the timing a bit to raise vac?
CRAIG
Post by CRAIG »
Timing seems ok, so I don't wanna mess with it. Would increasing the idle speed help?
Is it worth blocking the pipe from carb to pc valve on rocker cover and block the vacuum pipe to brake booster?
1969 Dodge Charger
Maybe with the cam that is installed that is all it makes.
Many of my cars have only made 5" Hg at idle....
CRAIG
Post by CRAIG »
Ok, I will check again tomorrow and see what vacuum im getting.
1969 Dodge Charger
