Not really! but my car I thought may have gone down a touch when the engine went in.
It looks like its jacked up? possibly like a set up for drag racing?
Ideally I had wanted the car to sit a little lower all round.
Car has not had an engine fitted for a while, and have only changed the rear shocks running 60 profile all round tyres.
Any thoughts?
4x4 charger!!
you can bring the front end down using the torsion bar adjusting bolts on the lower con trol arms.Piece of cake.
Rear end is trickier . If you've fitted new springs they may take several months to settle. Otherwise you'll need to use lowering blocks & longer U-bolts. Is everything installed at the back ? Fuel tank , rear seats , rear glass? It'll all make a difference.
Hiya Matt,
the glass is in however there is no fuel tank or rear seats, come to think of it the trunk lids not on! DOH!
I will wait till its all together and then moan about it!
I think maybe its me, been looking at other pics and it some do look a little high.
Will have a look at that torsion bar adjusting bolts though if it is still a little high once I have driven it, maybe it will settle?
Thanks
Thanks
