Engine parts help?
TIB3300
Engine parts help?
Post by TIB3300 »
Yes its me again :?
Can anyone help with some questions please?
All for a 318 LA Engine
Are all starter motors the same, auto/ manual?
Where to get one of those high torque small starters?
Best place for a stroker kit ?
Best place for a conversion set?
I will keep all my engine questions to this one post and just add them as' and when' thanks :thumbright:
graham fury
Re: Engine parts help?
Post by graham fury »
you can get a starter from real steel in uxbridge they may do the other parts you need they have quite a lot of stuff on there website
TIB3300 wrote: Fri May 08, 20 6:52 am
Are all starter motors the same, auto/ manual? - Yes
Where to get one of those high torque small starters? - Hausers, Real Steel, even some sellers on FB
Best place for a stroker kit ? - Really depends on what you want to do,what type of engine you want to build,
Best place for a conversion set? - Did you mean Torque Converter
Most Stroker units are based on the 360 so they are externally balanced... lots of research required....
TIB3300
Post by TIB3300 »
graham fury wrote: Fri May 08, 20 9:23 am you can get a starter from real steel in uxbridge they may do the other parts you need they have quite a lot of stuff on there website
Thank you :thumbright:
TIB3300
Post by TIB3300 »
mopar_mark wrote: Fri May 08, 20 9:36 am
Are all starter motors the same, auto/ manual? - Yes :thumbright:
Where to get one of those high torque small starters? - Hausers, Real Steel, even some sellers on FB :thumbright:
Thanks for the input :thumbright:
"conversion set"
No a gasket set
https://www.ebay.co.uk/itm/Fel ... 0012.m1985
TIB3300
Post by TIB3300 »
Pete wrote: Fri May 08, 20 9:47 am Most Stroker units are based on the 360 so they are externally balanced... lots of research required....
How are the 360s balanced?
Flywheel and front dampener? Are they physically any longer with the external balancing?
"research "
Yes, but thats been the name of the game all along with this one :read2:
TIB3300
Post by TIB3300 »
I dont really know, as have said .This is all new to me. :roll:
What I want is the car to sound like this
I know its a big block and that it has a 3.75 stroke where as the small block has 3.31 .I was hoping by incresing the stroke to 4in along with a cam, It would sound more like a big block :-k
Stroking an engine to try & emulate the sound of a big block, is not really a good recipe. You could change the idle characteristics with a Camshaft change, but you will be limited on cam choice by Piston to Valve clearance, this can lead to new cam, new lifters, the list goes on & on.
For noise, maybe a better option for you would be an exhaust cut out system, which you can change engine note(open headers) with a flick of a switch.
hi torque mini starters
you just need a mopar starter...
they are all much the same and by their nature were MINI and starters and the High torque bit is a function of the windings and the reduction gear.
they have the nose that fits into the bellhousing as standard i.e what brand x calls a heavy duty starter
so this one would do
https://www.rockauto.com/en/moreinfo.ph ... B6QYJ5o%3D
starter for dodge dakota 1995 with 318 5.2 litre engine gets you a starter that fits just about any muscle car era mopar
if you are californian
Attention California Customers - WARNING: Cancer and Reproductive Harm - www.P65Warnings.ca.gov
so don't lick the grease or drop it on your family allowance
its bolt holes are in the right place
its pinion is about 35 mm which sits it in the right place
it has a support snout that fits into the register in the bell housing
it just isn't painted bright red with lightning bolts and fancy chrome bits and it doesn't have multifit snout
this starter is converted to high torque by reseallers when they install a different OEM (Denso) armature and coils. or they use they long case motor unit on a mopar snout, from a diesel application.
if you run into difficulty with pinion size WOSP engineering in the UK can help but you won't with this on a 318 or indeed anything upto a 440 in a mopar with a US mopar bell and US mopar flywheel or torque converter ring gear.
this starter doesn't work with aussie 146 tooth ring gear applications using aussie converter flywheel and bell, where the bellhousing is in essence too small for the flywheel/converter/ring gear. they need a 25 mm pinion... or 27 (don't ask)....
and any mopar v8 sounds good, with the right pipe, due to the firing order and the positioning of the crank journals
TIB3300
Post by TIB3300 »
mopar_mark wrote: Sun May 10, 20 7:27 pm Stroking an engine to try & emulate the sound of a big block, is not really a good recipe. You could change the idle characteristics with a Camshaft change, but you will be limited on cam choice by Piston to Valve clearance, this can lead to new cam, new lifters, the list goes on & on.
I am going to thank you Mark as you probably know a lot more than I do. :salute:
These are just questions ???
Is it not true that a big block sounds slower / longer sounded when pulling away, if you know what I mean?
Than a small block?
I have been looking at cams, there seems to be a few I have seen
Voodoo
Thumper
I like this sound
TIB3300
Post by TIB3300 »
Dave999 wrote: Mon May 11, 20 3:27 pm hi torque mini starters
Thanks Dave
Thats what I read about the starters, but its good to have confirmation :thumbright:
Mopar V8 sounds good Best :thumbright:
No probs
i spent £36 on a starter 30 on shipping and then had pinion issues, Mine is aussie. the pinion cost more than the starter.....:) you should have no such issues.
If you do go the Cam replacement route, you should seriously consider getting a new Timing chain set. Some of the 318’s had an aluminium gear with plastic style teeth which can strip or should I say mine stripped on my ol 318 Challenger
TIB3300
Post by TIB3300 »
mopar_mark wrote: Mon May 18, 20 7:02 pm If you do go the Cam replacement route, you should seriously consider getting a new Timing chain set. Some of the 318’s had an aluminium gear with plastic style teeth which can strip or should I say mine stripped on my ol 318 Challenger
I have two engines both are 318, one is complete and is to be said in good order, the other engine is in bits and the one I am using for fitment.
This is the one I want to rebiuld with new internals and cam ect :thumbright:
