Fuel tank sealer
Fuel tank sealer
Anyone got any ideas/advice on something to use to seal a fuel tank leak from the outside ?
The leak is tiny and adjacent to the seam. Unfortunately, the area will never be dry (it is right at the bottom of the tank), so not sure how to seal it off.
Any help gratefully appreciated.
All the best
Bryan
Post by Bryan »
i got some stuff called `dam it` from vauxhall motors once they used it if any oil barrels got a punture it says it only lasts 24 hours but if its a small hole you might br alright, pm me your address and i will send you some up in a jiffy bag.
Alex
Post by Alex »
Petro Patch has worked really well for me in the past with small leaks, I think it is made by Comma and readily available
Petro Patch...... Good stuff.
TrevD
Post by TrevD »
I sealed my tank with"JB WELD" as a tempory mesure , that was 2 years ago , the replacement tank is still in the shed :shock: , now im fitting a fuel cell so dont need it anyway.
