Dominator Carbs
Guest
Dominator Carbs
Post by Guest »
Anyone know how the CFM on a 750 Dommy is set - from looking around it looks the the primary and secondary venturi and throttle bore are the same size on a 750 as a 1050.
Ive changed the spec again - its a monthly thing - and it now looks like I will be spinning the engine higher than the 750 (which supposedly can flow to 800) can handle.
Only problem is I bought a 'baby' dominator a month or so ago - thinking this would fit my planned engine OK - which is not now the case.
I have noticed that the annular boosters are HUGE and take up most of the venturi - so is this how its been 'downsized' CFM wise and is it as simple as getting a set of 1050 boosters http://www.barrygrant.com/bgfuel/default.aspx?page=69
Damn this engine building lark - driving me round the twist 8)
Cheers
Iain
Guest
Post by Guest »
Just in case anyone is wondering WTF im on about :D
Took a pic tonight, the umbrella arrowed is the area that I think is restricting flow.
The pictures from the Barry Grant site dont show these - so im therefore taking an educated guess that by removing mine and replacing with the new ones my CFM will increase (though needing re-jetting)
Any thoughts?
Guy
Post by Guy »
Ian can you remind what size is your motor and what sort of rpm you will be taking it to ?
Before changing the annular boosters check that there are no differences in the internal fuel circuits you may just end up putting in more air than they can supply fuel. I used a 750 dommy on my Nova and that reved freely to 9000 mind you it was a 331 sbc.
Guest
Post by Guest »
Guy,
It looks like I have finally settled on a 427+30, spinning to 7000
Would like it to go higher, but my oval ports will run out of air :cry:
Also running a solid roller - hence the recent change needed in CFM as I would have been spinning to less RPM with my original plan.
If I can get the heads to flow more - then obviously this will all change again (as in I will Bananarama! further)!
Dont need 1050 CFM - more along the lines of 850/900.
According to the Holley site - the only differences between then (apart from the boosters) is the jetting - everything else matches between the 750 & 1050
Thanks for your help - appreciated.
P.S. dont really want to sell this set up - as I have lost enough money by being indesivice and selling the original induction system
Hmm,I'm sure I read somewhere that changing the boosters needs a special tool and is not the sort of thing us amateurs should be messing with! I don't know if that is the only difference either! If you decide to get rid of the carb let me know, I'm thinking about getting one myself...
Guest
Post by Guest »
Blue wrote:Hmm,I'm sure I read somewhere that changing the boosters needs a special tool and is not the sort of thing us amateurs should be messing with!
Yup - I have head the same though im not sure what the tool actually does :( I had intended to pass the work out to either Peter Knight or ICE as it 'should' be less than an hours work - popping 4 boosters and replacing with new (I would have though)
If I do sell - I will let you know (more money lost - and this cost a small fortune as its never been run 8) ) so will explore this avenue first
Mick
Post by Mick »
Matthew Wright's 440 escort has got a 550 lift solid cam and he runs a 1150 dominator and claims he has jetted it bigger.
A lot of people i have spoken to reckon Mopars love big carbs
Hey Mick, were you talking to the carb salesman?? :D
Guest
Post by Guest »
Mick wrote:Matthew Wright's 440 escort has got a 550 lift solid cam and he runs a 1150 dominator and claims he has jetted it bigger.
only a 550 lift..... oops, this one is a tad higher :wink: though if I dont go with this cam - the lift will be reduced to around .680'ish
One of these days im going to decide on a spec and stick with it, otherwise its never going to get finished :cry:
I heard that too Mick, I bought an 1150 from Ted, he has run 'em on a few 440's, he swears by 'em!
Yeah a six pack is supposed to be 'too big' in theory for a stock or mild 440. 750cfm or 850cfm is as big as most people go.
A six pack works out to be around 965cfm in 4bbl terms. Even though mine opens manually (not vacuum operated) the engine loves it.
Mick
Post by Mick »
I've just put a 1050 on my Dart, it looks absolutely enormous. Sounds nice though.
I think using one on the street could be a bad move i had to pour half a gallon of fuel in just to start it.
If i put the car back on the street i will put a 850 d/p on it.
Yep, that's exactly why i'm thinking of getting a 750 dominator, it would be an easy swap at the track.
Mick
Post by Mick »
I presume by that, you mean 750 to 1150.
Good idea.
Guest
Post by Guest »
Blue wrote:Yep, that's exactly why i'm thinking of getting a 750 dominator, it would be an easy swap at the track.
Blue,
You have a PM that might be a solution to both our problems 8)
Cheers
Iain
(off to count the wifes contractions :D )
