header paint
header paint
anybody used a high temp. paint that actually works? I want to paint my headers,then wrap them (in exhaust wrap,not cotton wool :lol: ) It`s years,in fact decades since I used something like this & results were poor :!: ,the headers are off the car.Any imput would be appreciated(even funny)
Why paint them if you are going to use exhaust wrap?
The exhaust wrap will rot the headers out from the inside-out within a few thousand miles no matter what paint you put on them.
MrNorm
Post by MrNorm »
Well, I don't have a recommendation for paint, but it seems the key to longevity is preparation (as always huh!). I've heard people praise and cuss the same product (VHT hi temp comes to mind!), the difference usally being that the ones that lasted well has the headers sandblasted first.
Also, on the topic of header wrap, despite the benefits I've heard it can trap moisture and promote quicker rusting.
That's what 2c gets you!
MrNorm
Post by MrNorm »
Your turn this time Dave :D (both 1:56 but you are obviously quicker on the return key!!)
I always have headers aluminium sprayed, ( I get the whole system done when I make one) it stays looking good for years, you should be able to find a firm locally that can do it, costs around ?60-?80 the pair. the finish is a slightly rough silvery white. It will also not come off if or should I say when, you scrape the headers when installing them, paint would just come off in that situation. I've never found the high temp paints to last very long,I gave up with those years ago. I don't like header wrap either, it has a nasty habit of holding in condensation causing the headers to rust away prematurely. You can see the aluminium coating on the system in the photo, the headers on this car are nickel plated, which is expensive and not as rust resistant.
Thank`s for the replies :D ,and for the info on header wrap :shock: ,won`t be using that
MrNorm
Post by MrNorm »
Good point, I second Blues suggestion - that's what I'll be using on my exhaust (my headers are already coated). I've seen that on several of Blues systems and it looks great, is affordable, and lasts well!
Out of interest, in the US you can get this DIY Ceramic coating. http://www.caswellplating.com/powder/ceramics.html Dunno if it's available here, but you can see the importance of preparation by reading the instructions. If you prepared to this level even with a traditional hi-temp paint, I reckon it would last OK.
But when you look at the time involved, the ali spray still seems a no-brainer to me
Yep, prep is the key, the price I quoted includes sandblasting which they do before spraying on the ally coating.
Rich
Post by Rich »
What sort of firm has ali spraying facilities?A powder coating type place??Is there an industry that uses ali spraying a lot??Any help apriciated as I`m not sure where to start looking in the old yella pages.
I'd look under metal spraying, or industrial finishes, a firm that does powder coating might do it too. The firm I use is called RFI Screening and it's all they do so it must be a popular finish for all sorts of things.
Sounds like this mob do it, not too far from you...
http://www.yell.com/search/ShowMap?nat_ ... ed%3D26109
They seem to be listed under "blast cleaners" for some reason...
Rich
Post by Rich »
Thanks for your efforts Blue.I am taking my headers out now for a quote :wink:
Burnt all my header paint off yesterday...YES!! :wink:
Ivor said;
You fired her up then Ivor?
