worth converting to RH thread wheel studs?
Well the sun is out so I dug the Fury out of the barn and tried on some new wheels I got for it. Then i remembered the LH side of the car has LH threads. I need to order a set of nuts for the new wheels.
Is it more expensive to get LH thread ones, and also is it worth just converting to RH thread studs, and if so where would be the place to get these? They are 1/2 unf same as Charger etc. Car has drum fronts if that makes a difference.
Mr Tee. Mr Tee. Who is that bloke? It's a mystery.
DaveMadders
Post by DaveMadders »
Tim at Raceways cuts LH thread nuts on site.... 01283 517935
Dave Madders 0161 428 4281
thanks but what would you do, change studs or buy LH nuts?
and by the way, do these wheels look good on here or what!
First thing I did with the Chally was change to RHT studs because I knew it would probably confuse me and there were a couple that were already sheared off due to confused US tyre monkeys.
But as I was buying loads of stuff from Year One at that time to replace all the missing bits on the car it was a simple matter to add a set of studs to the order.
Those wheels look spot on Will. Much better than the others. I would say go for it. :D
Matt
Post by Matt »
The front studs are swaged over onto the drums after installation through the hub and are extremely difficult to remove.
Much easier to get LH nuts . Raceways at Donington have a good selection including unilug etc
MrNorm
Post by MrNorm »
Agree......change to RH studs, only a matter of time before someone knackers the LH ones.
EDIT....did not read your cars has drums! From what Matt says maybe switching is not such a good idea with drums.
Or...get discs!
thanks Matt! i knew they were tight but didnt know they were like that. Lh it is then.
My car had drums. :dontknow:
ordered 10 left 10 right from raceways.
just gotta get 2 more wheels now :)
TrevD
Post by TrevD »
are they large or small PCD, i have the ones i took off the duster, i think they are 7x14, large pattern, good tyres.
large (4.5) i've found a guy in scotland selling a pair same size as mine (15 inch) so hopefully im ok, thanks.
